unconfigure vlan dhcp-options
unconfigure {vlan} vlan_name dhcp-options {[ default-gateway | dns-server {primary | secondary} | wins-server]}
Description
Unconfigure the DHCP option information for the specified VLAN.
Syntax Description
vlan_name Specifies the VLAN on which to unconfigure DHCP.
default-gateway Specifies the router option.
dns-server Specifies the Domain Name Server (DNS) option.
primary Specifies the primary DNS option.
secondary Specifies the secondary DNS option.
wins-server Specifies the NetBIOS name server (NBNS) option.
Default
N/A.
Usage Guidelines
None.
The following command unconfigures the DHCP options for the VLAN temporary:
unconfigure temporary dhcp-options
This command was first available in ExtremeXOS 11.0.
The primary and secondary DNS options were added in ExtremeXOS 12.1.
Platform Availability
